Can the Action 5 handle saltwater without a case?
Might be a dumb question, but can the Action 5 go in saltwater without a case? Everything I’ve read says it’s fine up to a certain depth, but saltwater destroys everything, so it feels risky!
Water is water. As long as it’s within the 20m depth limit, it should be fine.
Can it survive lava too? Asking for a friend.
Go ahead and test it, then let us know what happens.
Yes, as long as you stay within the recommended depth. If you’re worried, stay under 10m just to be safe.
  • Make sure all the doors and seals are properly closed.
  • After using it in saltwater, rinse it well with fresh water to prevent salt buildup.
