Crashed my Mini 4 Pro just two weeks after I bought it... what should I do?
After purchasing my drone from abroad through a friend of mine, I brought the mini 4 Pro into India. After few wavy flights the past week in normal mode, I wanted to test out the sports mode.
And this happened!! I flew into a transmission line and the drone fell into a paddy field half immersed in water. I haven’t turned it on yet.
From here, what do I need to do to fix the broken arm and how do you drain out the remaining water (it’s almost dry now)
FYI …there is no authorised dji drone care in India and neither do I have a dji care refresh.
Hope you guys would help me out!! Thanks in advance!!
Unfortunately, I don’t think there’s a way to fix it. Mini drones are really light and super fragile. That mechanism would be tough to replace since DJI is not officially available in India. Try to find a replacement arm online. You might have to do some DIY and figure out how to ship it to India.
@Bailey
You can fix it. Just order a new arm actuator and an iFixit screwdriver kit.
Lessons learned. Going forward, keep line of sight and avoid cables and trees. The avoidance system struggles with small obstacles like cables and bare branches. Sorry about your loss. Best of luck with the repairs. Maybe send it to DJI or find a local DIY repair.
@Nyle
Thanks… definitely learned a lesson the hard way.
Reset the counter: 0 days since last incident.
More like 0 days since having a working drone.
Now that I’ve done it… I wouldn’t want to reset anytime soon.
Don’t turn it on, just place it outside in the sun to dry. Try to find a local repair shop or send it to DJI as is. They will test it before giving you a quote. If it doesn’t turn on for them, they’ll have made sure everything was done right first.
@Jamie
Thank you… I’m not turning it on and keeping it out to dry. Soon I’ll have to find a way to get the arm back on.
HoverHero said:
@Jamie
You might also want to add silica gel packs or something to remove the moisture inside the drone.
@Yani
Thanks… I dried it in the sun, but now I’ve put in silica gel packs to get rid of any extra moisture!
Are there local repair centers that can repair DJIs? There should be since DJI isn’t official. Otherwise, you’ll need to carefully take it apart and let it dry. Remember that arms are sold separately, so they can be replaced.
Hit me up, I do repairs in Singapore.
I’m in India too. There are third-party DJI service centers you can contact. Xboom, Airytek, and HobiTech are your best bets. I bought my Air 3S from Airytek, and they cover me with their warranty. They’ll take care of repairs.
@Zya
Thank you… I’ll reach out. By the way, where are they located?
HoverHero said:
@Zya
Airytek can handle minor work in BLR, but a major repair like yours would be sent to Kerala. Contact them, show them pictures, get quotes, and compare. Choose whoever seems more professional and responsive.
@Zya
Definitely will do that… I’m in Tamil Nadu, so getting it to Bangalore or Kerala shouldn’t be a hassle. Thanks again!!
HoverHero said:
@Zya
I guessed as much. The mention of paddy fields made me think of TN, and South India has more drone hobbyists than North India.
Why doesn’t DJI have a presence in India?
