My drone setup includes:
- 4-in-1 ESC
- Flight controller
- Telemetry set
- Radio receiver
- GPS + compass module
- Camera
Do I need a power module to connect the battery to the ESC and flight controller?
A power module is typically used with autopilot hardware to provide voltage and current sensing, as well as power to the flight controller. If your flight controller has built-in voltage regulation and current/voltage sensing (or uses external sensors), a separate power module isn’t necessary.
@Peyton
Thanks! My flight controller specs mention:
So, I’m assuming I won’t need a power module, correct?
Beckett said:
@Peyton
Correct. With BECs providing adequate power and sensing capabilities, you shouldn’t need a separate power module.
@Peyton
Great, thanks for clarifying!
You’ll need to solder a battery connector, like an XT30 or XT60 (depending on your battery), to the ESC for power. Your flight controller’s instructions should include a wiring diagram showing how everything connects.
