Doesn’t it do this when the batteries are too hot? Did you start charging right after using them?
That’s not normal. The lights should blink and show the charge level, then start charging the most full battery. Yours seems to cycle. Maybe try using a stronger wall charger.
It doesn’t look normal to me. Maybe you should get a replacement.
You need a more powerful charger.
I think it’s the opposite for me. I used a 65W charger and got a message that the power was too much. When I switched to a 35W charger, it worked perfectly.
My Neo does this too. It eventually charges fully. I think it’s just waiting for the battery to cool down before charging.
This happened to me with a charger that was too powerful. Try using a lower wattage charger.
Try using a different power brick and cable.
This is the original DJI cable.
What about the power brick? Is it the original one?
Try a 30W charger.
It seems like there’s not enough input power. It’s behaving like when my Avata 2 charging dock is pulling power from other batteries to make one fully charged battery from partially charged ones.
