I recently lost my DJI Mini 3 Pro drone while flying. I was about 350 meters away, doing a hyperlapse at a low altitude. When the battery reached 50%, I tried to bring it back, but it wouldn’t respond to most commands. The RTH button didn’t work, and it eventually auto-landed.
I’ve searched the last known location on foot and by air, but I haven’t found it. The area is tough to navigate, and I’m not sure if I’m missing something.
Has anyone had a similar experience or knows how to recover a lost drone in this situation? Any advice on why the drone lost control or how to use flight logs and GPS would be helpful.
Sorry to hear about your drone. You can try these steps:
Go to the Flight Controller Settings and tap ‘Find My Drone’. An aircraft icon will show up on the map so you can see the drone’s last known location. You can also share this location with a QR code.
Use the PinPoints feature in the flight records and map views to generate location info, and share it through a QR code.
Scan the QR code with your phone to get the location and then use the map interface to track your drone.
Also, you can file a flyaway case on the DJI website. If the drone is under warranty, you can get free data analysis. Link to the DJI flyaway page
Aris said:
Did you try canceling the hyperlapse and then using RTH (Return to Home)?
Yeah, I tried, but by the time I thought about using RTH, the drone was already done with its flight. I even turned off my remote controller and turned it back on, but nothing changed.
@Zion
I was flying in a mountainous area, on top of a hill. The drone was only 350m away, but the terrain was too steep and full of cliffs, so it wasn’t possible to walk there.
I do have the flight log, and I’ve been using the last GPS coordinates to help guide my search. I couldn’t find it on my first attempt, but I’m going back tomorrow with a trail expert to help me get to the location.
