Motion control drone (Red5) won't turn on… any ideas?
I’ve been trying to get my Red5 motion control drone to work for a couple of days, but it just won’t turn on. The controller seems fine, the lights turn on, but the drone does nothing. I’ve followed all the instructions, watched a bunch of videos where they connect the two wires and the drone lights up, but mine isn’t doing anything at all. I even swapped the battery, thinking it might be the issue, but it’s still not working. I’m new to this, so I’m probably messing something up. Is there a button I’m missing? Am I charging it wrong? What am I doing wrong? Any help would be really appreciated.
Can you post some pictures of it? It looks like this might be a cheaper drone, so maybe it has a manufacturing problem or the motherboard is faulty. Also, check if the battery is connected properly and make sure the wall charger isn’t too powerful for it.
@Nash
Here is a photo: https://placehold.co/600x400.png
@Keir
Try charging it using your laptop. Sometimes devices won’t charge properly with a wall charger that pushes too much power.
Nash said:
@Keir
If I don’t have a PC, is a laptop okay to use?
@Keir
Yes, a laptop will work fine as long as it has a USB port.
Nash said:
@Keir
Thanks, I’ll try it now. You’ve been really helpful :sob:
Keir said:
Nash said:
@Keir
How long should I charge it? The shop assistant said there’s a limit on how long you can charge it or it could damage the battery.
Keir said:
Nash said:
@Keir
It should stop charging automatically once it’s full. No need to worry about overcharging it.
