Why did my DJI Avata 2 crash out of nowhere?
Haru said:
Honestly, I’m still not sure why it crashed. Maybe I missed something?
If you look at some of the frames, you can see what might be a fishing line coming from the shore.
Well, if it was a line, at least it wasn’t a software issue.
I noticed some sticks on the right just before the crash. Could a thin branch have hit the props?
How far away was the drone when it crashed? Did you go back to check the area?
Looks like you pulled the stick too hard, and it couldn’t recover.
What’s that circle on your camera view?
Watched it frame by frame. I don’t see any fishing lines or obvious obstacles. The interference theory doesn’t make sense either. Honestly, this crash is a mystery to me.
Maybe someone on that ship was messing around with drone jammers. Just a thought.
This looks like the Avata’s known ‘flip issue.’ A fast yaw can cause the height reading to spike (like the +17ft you see). The safety logic probably misread this as a flyaway and stopped the motors. Those white lines look more like display UI elements, not fishing lines—they’re even drawn over the motor warning text.
What controller were you using?
That’s what happens when you fly so low.
You probably got snagged by the invisible kraken’s tentacle.
