It’s natural to feel anxious; after all, you’re sending an expensive piece of equipment into the air. I’ve flown a lot, but I still get a bit nervous. You’re doing the right thing by flying high to avoid obstacles. Remember, most consumer drones are very reliable these days, and there are safety features like Return-to-Home in case you lose signal or battery gets low. Trust your drone!
@Micah
I get especially nervous when it’s hard to see with my eyes, and I’m just relying on the screen.
Phoenix said:
@Micah
You could add a small strobe light. They’re lightweight and can help make the drone more visible, though it might draw attention.
The more you fly, the less anxious you’ll feel. Getting insurance can also give you some peace of mind.
If you’re flying in a crowded area, go up to 150-200 feet above everything around you. It helps avoid the risk of hitting something. People get uneasy when they see a drone hovering too low. Maybe try flying in a more remote area to build confidence. The drones are usually very reliable, and even if something goes wrong, DJI is pretty good about replacing faulty ones.
For me, flying regularly in different places helped a lot. The more I practiced, the more comfortable I got with higher altitudes, longer distances, and navigating obstacles.
Try using the Return-to-Home function a few times just for practice. Don’t disconnect the controller, but let it come back on its own to see that it works. It might help you trust your drone more.
What if I’m flying half a mile away at 100 feet high and lose connection? Will the drone calculate if it has enough battery to return home, even if it’s 2 miles away?
After flying for a few weeks, I found myself enjoying flights within a 150-meter radius and around 25 meters high more than exploring further. I don’t even need to use the camera that often.
I felt the same when I started. It just takes time and experience. At first, it’s hard to trust the tech, but you’ve got to crawl before you can walk.
Flying higher is actually safer because you’re away from birds, trees, and power lines. Anxiety can be good since it makes you more cautious. The drone won’t just drop out of the sky unless something like a bird hits it. Also, having insurance helps reduce the fear, especially when flying over water.
Same here. Just got a Mini 2 and I’m still a bit nervous about sending it too far or high. It’s a work in progress.
I got some small strobe lights that attach to the drone with Velcro. They make it easier to spot, especially at dusk. Plus, taking it one step at a time really helps with the nerves.
Get insurance and keep practicing. Don’t let the anxiety discourage you!
Right there with you. I feel the same every time I fly.
Get a Neo. It might be worth trying.
I actually had a Neo before, but I sold it because it doesn’t have collision avoidance.
It’s normal to feel anxious flying your drone. Here are a few tips that helped me:
- Start Low: Fly at lower altitudes first until you feel more confident.
- Trust Your Drone: Modern drones are designed with safety features that help handle high flights.
- Fly in Open Areas: It’s easier to stay calm when you’re not surrounded by obstacles.
- Stay Calm: If you start feeling anxious, take deep breaths to relax.
Over time, you’ll feel more comfortable. Don’t rush it.
I just look at the screen and fly as if it’s a video game.
Do you only look at the screen once it’s in the air? I’m never sure where to look.
