I’m having a lot of trouble with my Air3S. I often shoot sunset panoramas using 3-Frame-AEBs, which I merge and edit in Lightroom. But with this drone, I’m running into major problems with the de-ghosting feature. All my previous DJI drones (Mavic, Mini2, Mini3pro, Air2S, Air3) worked fine, but now with the Air3S’s DNG files, Lightroom goes crazy with the de-ghosting, especially in the bright areas. Even on the lowest de-ghosting setting, it still shows a lot of differences that I can’t even see. If I turn off de-ghosting, I end up with horrible edges. I’ve tried adjusting all sorts of settings, including resolution, AEB frame amount, and both manual and auto settings. Air3S and Lightroom are both on the latest firmware. I suspect the Air3S might be doing some internal HDR processing that Lightroom can’t handle well, causing issues with those fake raw files. Has anyone else experienced this?
Haven’t had any issues with it…
Are you using Windows or Mac?
I’m on Windows. To be fair, I’ve only done about 3 panoramas with the drone, and they didn’t give me any problems.
@Tait
Were you using Panorama or AEB for HDR?
Just panoramas.
I’m talking about merging AEBs into an HDR image. Panoramas are a different thing.
Just panoramas.
I’ve only tried the free panorama mode, not the other ones.
