Just a quick heads up… it’s basically the same Power 1000 but with two more AC output ports and the AC power output bumped up to 2600W.
Do you think it’ll have built-in app control now or still need that dongle thing?
Wait… what do you mean 2.6kW AC output? Is the battery still only 1kW?
Yeah the original Power 1000 already had 2.2kW AC output. They’ve just raised it a bit, but it’s still got the same 1kWh battery inside.
@Thayer
Got it… so they just gave it more AC output power from the inverter side.
Haru said:
@Thayer
Or maybe the battery can handle faster discharge rates now.
Just to be clear—it’s 1kWh, not 1kW. kW is power, kWh is how much energy it can store. If you run something at 2kW, it’ll be empty in half an hour.
