Can a drone be used for crop dusting with pollen?
I don’t know much about drones, but I was wondering if it’s possible to use one for something like crop dusting, specifically to spread pollen in an orchard. I’m not an expert on drones, I’m more of a dirt and plants kind of person. I have a small area now but am looking to plant a small orchard. The weather where I live can be unpredictable, so bees don’t always show up in time. Could I use a drone to spread pollen in the trees? Is this even feasible or does it sound ridiculous?
I’d appreciate any advice! I’m only talking about a small area, around 4 acres max. Some people mentioned a large drone might be needed, but I’m open to ideas.
Yes, this is something that has been done before. Try searching agricultural drone uses online. Also, check out some techniques for artificial pollination.
The DJI Agras T40 was actually made for this purpose.
A 40-liter drone is overkill for 4 acres. A smaller drone, like a 7-inch model, should do the job just fine.
Yes, but you would need a large drone and a Part 107 license since this would be commercial use. There are people who do this, though.
Actually, you need a Part 137 certificate and an aircraft worthiness certificate, not just Part 107. Getting the approvals for these kinds of flights can be a hassle in some areas of the USA.
@Xander
Just a heads-up, you need a Part 137 certificate for this, not just Part 107.
Wait, so this is already a thing? That’s pretty awesome! Could you explain why you need a large drone? I meant for a small area, like 2-3 acres, which is why I asked.
@Micah
My bad for misunderstanding your first message. Yeah, for a small area and a small amount of pollen, a smaller drone should work. You might need to be creative with how you release the pollen, so it spreads evenly and doesn’t fall in one spot, but it’s doable.
@Teo
Thanks, I didn’t explain well enough, but ‘crop dusting’ just seemed like the easiest way to say it. And I have to admit, it’s kind of funny to think about!
Anyway, you seem to know what you’re talking about. How do you keep the pollen contained on the drone? I imagine there’s something else mixed in so it doesn’t just blow away in the wind?
@Micah
You could use a drone bait dropper, fly high enough, release the pollen, and the rotors will help spread it around.
Vic said:
@Micah
Are you speaking from experience, or just guessing how it might work?
@Morgan
Well, not to give too much away, but when my new neighbor decided to rip out his garden for turf, I may have dropped some wildflower seeds on his bare earth with a method like this. :wink:
@Teo
Whoops, looks like I need to follow r/rimjob_steve for a better way to say that!
@Teo
Have you actually done this for real or are you just guessing?
Yes, but for a significant payload, you’d need a much larger drone to carry the weight.
Pollen is pretty light, though. Could you explain why a large drone is necessary? I should have been clearer, but I’m thinking about a small area, around 2-3 acres.
