Can you put a thermal camera on DJI drones?
Would you like to integrate thermal imaging capabilities into your DJI drone?
By incorporating a Zenmuse H20T or H20N payload onto the DJI Matrice 300 RTK, you can capture unparalleled levels of high-resolution thermal data.
It depends on the specific models. The enterprise line (including Mavic 3T, Mavic 2 Dual, Matrice, etc.) comes with a factory-installed thermal option. The Inspire can be equipped with one after purchase. However, standard consumer models like the regular Mavic/Mavic Pro, Mini, etc., cannot be retrofitted with thermal capabilities.
It’s important to note that DJI’s consumer drones aren’t typically designed for thermal imaging applications.
They might not have the processing power or flight stability needed for professional thermal work.
