Compatibility: Foxeer with Speedy Bee VTX?
Is the Foxeer camera compatible with the Speedy Bee VTX? Do I need to install a separate Foxeer OSD, or is everything built-in with the Speedy Bee VTX? I’m excited about setting up my first build with the Speedy Bee and hope the components are compatible. Also, what are some of the best and most versatile FPV goggles? Thanks, and Happy Holidays! P.S. I’m considering buying a RunCam 2 for the Speedy Bee VTX instead of the Foxeer. Any suggestions? Also, any advice on setting up the OSD? Have a great day! :coffee:
Others here might have more specific answers for you. While you’re waiting, here are some tips:
  • Trim your leads to just cover the solder pad for cleaner connections.
  • Clean your soldering iron tip with a damp sponge or paper towel before each joint.
  • Secure your wires with thread to keep them out of the propellers.
Enjoy building and flying!
@Kiran
Thanks for the inspiration! I absolutely need practice, and I’m planning to go over my first build soon to resolder and tighten up the connections.
Please shorten your cables to the minimum length needed. If they’re too long, they’ll end up in your props the moment you throttle up.
Got it. I’ll make sure to shorten them, especially now that you’ve explained why. I’ve also learned a lot about securing connections and keeping things tidy. Thanks for the constructive feedback!
Foxeer is a brand, not a specific component, but they primarily make analog cameras. Assuming you’re asking about an analog camera:
  1. Compatibility: Any analog camera designed for drones should work with any flight controller and VTX meant for analog video. The flight controller simply passes the signal through.
  2. Flight Controller vs. VTX: The flight controller is the main board that controls the drone. The VTX (video transmitter) sends the camera’s video signal to your goggles or receiver.
  3. OSD (On-Screen Display): The flight controller provides a heads-up display with flight data. The camera itself may have its own settings for color and exposure, accessible through either smart audio/serial (via the flight controller) or a plug-in controller.
Make sure your wiring is clean and secure. Joshua Bardwell’s build videos are great for getting the hang of these setups.
@Kim
That’s excellent info—thank you! My Foxeer is definitely analog. My Speedy Bee VTX isn’t analog, though. I’m debating whether to stick with this setup or upgrade to something like a GoPro for better footage. Maybe I should focus on getting this current build working first and then decide.
@Sparrow
That sounds like a good plan. Take it one step at a time and see how your current setup performs. Also, consider adding a GPS module or buzzer to avoid losing your drone—both are super helpful, especially when starting out.
