Drone Forced Landing Twice Before Returning to Home Point – Need Insight
Hello folks…I’m having an issue with my drone and could use some help. On two separate occasions now, my drone has been forced to land before it could return to its home point. This has been happening even though I’m within the operational range and there are no obvious obstacles.
The forced landings are causing me some concern, and I’m unsure whether this is a common issue or if there might be an underlying problem with the drone. I’ve checked the battery levels and signal strength, and everything seems normal before the forced landing occurs.
Has anyone experienced similar issues or have any insights into what might be causing these forced landings? Any advice on troubleshooting or steps to ensure that the drone can safely return to its home point without interruption would be greatly appreciated. Thanks in advance :wink:
Even if your drone’s battery appears to be fully charged, it might still be faulty. Check the battery’s condition, ensure it is properly seated, and also monitor GPS signal strength and environmental conditions.
