I have a DJI Air 3 and I am planning to fly near Brunswick Airport, which is an uncontrolled airport, but within five miles of it. Although I won’t be flying on the day of the airshow, I’m wondering if I need to notify the FAA or the airport due to the proximity. What steps should I take? I have my trust certificate and the drone is registered.
Since you’ll be flying near Brunswick Airport, which is an uncontrolled airport, and within five miles of it, you do need to take some precautions. First, it’s a good idea to notify the airport operator of your flight plans to ensure there are no conflicts with manned aircraft. This is generally done as a courtesy and safety measure. You should also use an app like B4UFLY or Airmap to check for any temporary flight restrictions (TFRs) or other advisories in the area. Having your TRUST certificate and registered drone is great—make sure to follow all FAA guidelines and local regulations while flying. Enjoy your flight!
As long as you are not flying during the TFR, it is identical to any other airport in uncontrolled airspace.
Drones flying near airports could lead to a collision. Drone pieces dispersed across a flight line or runway may create tire punctures, resulting in blown or flat tires. If a drone is sucked into an engine, it may cause harm. That would be extremely harmful if the problem was not detected before flight and caused the engine to fail during flight.
While Brunswick Airport is uncontrolled, operating a drone within 5 miles of any airport requires extra caution and adherence to specific regulations.
Key Considerations:
FAA Regulations:
- Registration: Ensure your drone is registered with the FAA. You mentioned you have your TRUST certificate, which is a good start.
- Remote ID: Familiarize yourself with the Remote ID rule and ensure your drone complies.
Local Regulations: Check for any additional drone-specific regulations in the state of Georgia.
Airport Notices:
- NOTAMs (Notices to Airmen): These advisories affect flight operations. Check for any restrictions or temporary flight restrictions (TFRs) in the area. Access NOTAMs through the FAA’s website or mobile app.
Common Sense:
- Visual Line of Sight (VLOS): Always maintain visual contact with your drone.
- Weather Conditions: Avoid flying in adverse weather conditions.
- Aircraft Awareness: Be mindful of air traffic, especially near an airport.
- Airport Traffic: Consider avoiding flying during peak airport traffic times.
Additional Tips:
- Contact the Airport: While not mandatory, informing the airport of your drone operation can be a courtesy.
- Local Drone Clubs: Joining a local drone club can provide valuable insights and networking opportunities.
