Hey, I need to inspect my 100-acre fence and won’t be flying higher than 5-6 feet off the ground. What drone would be best for this? Looking for one with good battery life and range.
You could probably use one of the newer DJI drones with a few batteries. If your land is a square, each side is around 2,100 feet, so it’s doable. You’ll just need multiple flights and battery changes. I suggest recording the video and watching it after since hovering too long can drain the battery fast. Might not be perfect math, but it should work!
@Zion
You’re overthinking it. A 100-acre square is about 2.5 km around. You could probably do it with one battery.
Arin said:
@Zion
The Mavic 3 should handle it easily.
Arin said:
@Zion
Same goes for the Air 3. Unless you fly super slow, one battery should be enough.
@Shawn
I regularly get 35 minutes on my Air 3. You could do a few laps around 100 acres in that time.
Arin said:
@Zion
Get a drone with waypoint capability, and you can automate it for future inspections.
Arin said:
@Zion
I think my Air 2S could do this on one battery too.
Arin said:
@Zion
Even the original Mini could do it depending on how detailed you want to get.
Arin said:
@Zion
Yep, the Mini can handle this easily too.
@Zion
Watching the video on a big screen after the flight will help you catch more details.
Robin said:
@Zion
Can you hook up these drones to a big TV? No experience, just curious.
Robin said:
@Zion
Most drones record to MicroSD, which is easy to play on modern TVs.
Dane said:
If the distance calculations are right, you could easily do this with a Mini 3 or 4 in one battery. With waypoint missions, you wouldn’t even need to actively fly it.
Exactly. He could watch the whole thing on TV while the drone does all the work.
Sun said:
@Dakota
I meant live footage while it’s flying, not just recorded video.
Yes, it’s possible. DJI drones have remotes that can output video. I use a 4K monitor with my Mini 4 for live viewing. You just need the right cables and a power source for the monitor. You can also use a tablet or phone and screencast the live feed to your TV. There are some tricks to it, but it’s definitely doable.
Sun said:
@Dakota
Not sure about live feed directly to a TV, but there are ways to broadcast live streams.
Sun said:
@Dakota
Here’s a link to DJI’s livestreaming info that might help:
Sun said:
@Dakota
Yes, live feed to a TV is possible.
@Zion
Someone already did the math here… classic!
