How can I improve my drone's speed and control?
I’ve been flying in Sport mode, but the drone feels slower and less responsive than I expected. Are there adjustments I can make to improve the speed or fine-tune the controls? Any advice for getting better performance?
Were you flying in Sport mode?
Yes, I was in Sport mode.
Good question—it makes a big difference in performance.
If you’re looking for quick turns and better control, you might need to switch to an Avata or Avata 2. Cinematic drones aren’t really built for fast maneuvers.
Have you tried adjusting the rates? You can fine-tune the speed of yaw and pitch in the settings.
I wasn’t aware of that! I guess I need to watch more advanced tutorial videos. Thanks for pointing me in the right direction.
@Harlan
No problem—it’s under the control settings. Look for Expo and Gain. You’ll find what you need there.
Fine-tune your control rates. It can make the drone as aggressive as you want it to be.
Each mode, including Sport, can be customized. Adjust the Gain and Expo settings for better control.
YouTube is your friend! Search for videos on how to adjust control rates and settings.
It’s not the fastest drone out there. Try an Air 2S with Master Airscrew props if you’re looking for a real boost in performance.
Sport mode is a good start, but you can tweak settings further to get the best performance.
