How Does This Work?
I just bought a used DJI Neo Fly More on Facebook without an RC controller. I got it set up and can do the follow-me feature, but how do I use it for drone activities? What can I do with this little device? Also, I’d appreciate any advice for night flying, as I tend to fly more in low light conditions.
First of all, it’s highly recommended NOT to fly the Neo in low light conditions because the downward sensor cannot detect the ground.
To do more ‘drone activities,’ you’ll need to activate and pair the remote (which you currently do not have and is necessary for normal flying) with the Neo and your DJI Fly account. From there, follow the tutorial for flight. Since you lack the controller, you can only fly via your phone or use the AI subject tracking mode.
@Tanner
So I need a controller for most functionalities. I figured out flying on the phone, but I’m wondering how to control it while focusing on a subject.
Kip said:
@Tanner
Yes, you’ll need a controller.
Kip said:
@Tanner
Correct.
Get a compatible controller to use it like a regular drone.
Avoid flying at night.
Since it seems you’re new to drones, please research the drone regulations and laws for your area. Don’t give drone users a bad reputation by neglecting your research or preparation.
@Vann
I’ve done all the research, and in my area, you basically need nothing. Why shouldn’t I fly at night? Is it software-related? I have open areas.
Kip said:
@Vann
Because the sensors aren’t very effective in low light, so if you’re okay with potentially crashing your drone and losing your investment, then sure, go ahead and fly at night.
@Farrell
Also, the video quality at night won’t be good. The sensor is too small.
Kip said:
@Vann
I don’t even think the Neo will allow takeoff in low light conditions.
@Ode
Okay, I wasn’t sure. Everyone seems really hostile about that idea, but I’m just thinking that if I’m visually flying with manual control, why shouldn’t it? But if it’s a software limitation, that’s fair enough.
@Kip
I think people seem hostile because we take drone flying seriously, and it looks like you’ve put little thought or preparation into acquiring and using a drone. It’s obvious that you’ll need a compatible controller for manual control. You can also control it from the app.
@Vann
I’ve put a lot of thought into it; thank you. I figured out the app controls, but I was just confused about how essential a controller is for the Neo specifically, as it advertises in-app manual control.
@Kip
I’m not entirely sure about the Neo, but I believe the app connects to the Neo via Wi-Fi, which has a limited range. The controller utilizes dedicated software and offers a much larger range. Additionally, using joysticks on the controller provides better control than the on-screen joysticks in the app.
@Vann
Perfect, thank you! I also saw that the controller lets you choose/draw subjects and gain more manual control of the drone itself… Do you have any recommendations: N3 vs RC2?
Kip said:
@Vann
I’ve heard that the RC2 controller (with the built-in screen) doesn’t have as good a range as the RC-N3 controller. However, since the Neo is very lightweight, you probably won’t want to fly very far with it as it’s more susceptible to wind. To be honest, YouTube likely has all the answers you’re looking for regarding its usage and controller compatibility.
@Vann
Thank you so much! I’ll check that out!
@Kip
You put a lot of thought into it but bought a drone that won’t fly at night.
Windsor said:
@Kip
I bought it* and that was my question, wasn’t it? Is it software that stops it? Obviously, the camera isn’t great, but that’s not the point.
