How much is this DJI drone setup worth?
Hi everyone,
I recently bought a DJI drone package at an auction, but I have no idea what I’ve actually got here since I’ve never flown a drone before.
It’s a DJI Matrice 210 RTK V2, which I think is from around 2017.
Everything seems to be in working condition, but it’s missing the small controller batteries, a camera, and the CrystalSky display.
Here’s what’s included in the set:
  • DJI Matrice 210 RTK V2 drone
  • 2 controllers
  • Multiple batteries
  • A battery charging station
  • Protective transport cases
  • Spare propellers
I’d love to get an idea of what this might be worth if I decide to sell it—or if it’s worth keeping and getting into drones as a new hobby.
I’m based in Europe, if that helps with the valuation.
Thanks in advance for any advice!
The Matrice is made for industrial and scientific work—stuff like building inspections, bridge surveys, and thermal imaging.
It could be valuable to the right buyer, but for most people, it’s not really useful.
@Hollis
Didn’t even think about that. I guess it’s not really meant for casual flying or fun use. I’ll do some more research before messing around with it.
Hollis said:
@Hollis
Yeah, but depending on what’s attached, it might have a high-end camera that adds to the value.
A lot depends on how much life the batteries have left. Keeping this drone running isn’t cheap—you’ll probably need a compatible camera and a proper display.
I used the CrystalSky screens, and they were solid.
You’ve got like 80% of a working kit here, but the missing parts might be pricey.
@Atlas
At the auction, they said the batteries were barely used, but I know it’s a ‘sold as seen’ situation. Might be some dead ones in there.
I read somewhere that you can check battery health with an app—any other ways to test them?
@Hollis
Best way? Just use them.
You can check charge/discharge cycles by plugging the battery station into a computer with DJI Assistant (I think). But at the end of the day, you’ll have to charge them up and see how much flight time you get. Should be around 30 minutes, but probably less.
Also, check for swelling! If any of them are puffy or deformed, don’t use them.
You’ll also need WB37 batteries for the Cendence controller.
@Atlas
Good to know! I’ll get some WB37s and check if the drone batteries and controllers still work. Appreciate the help!
This comment was removed by the admin.
Check eBay for recent sales.
The missing camera is a big deal—probably takes a huge chunk off the value.
Where are you located? Some countries have really strict rules on flying these.
I’m in Luxembourg. Pretty sure you need a permit to fly any drone here, but I’ll have to look up the specifics for this type.
@Hollis
Laws there seem similar to what we have in the UK.
Here’s a link with more info: Frequently Asked Questions - Directorate of Civil Aviation - The Luxembourg Government
@Hollis
You should think about where you’ll actually be able to fly this thing.
For example, the law says: ‘In A3, you need to be at least 150m away from any industrial, commercial, residential, or leisure site with a UAS class mark C3/C4 or an unmarked drone between 250g and 25kg.’
That could make things tricky depending on where you’re planning to use it.
Honestly, without the missing parts, it’s not worth much.
You’d have to find a compatible camera, and without the display, it’s basically unusable.
Newer drones weigh half as much, fly longer, and are cheaper than the M210 was back in the day.
If you factor in depreciation… maybe 5 bucks lol.
