Important advice for drone owners… don’t skip maintenance!
Just a reminder to take care of your maintenance. Rainy days are great for updates and regular maintenance so your drone is always ready for action.
New to drones! What kind of maintenance should I be doing? Mine is still in the box far from where I am, but I’d like to be ready when I get it.
You’ll want to check for cracks (especially on the props), install updates, and cycle your batteries (charge/discharge them fully a few times each year). Also, look for swelling in batteries and check if there have been any updates to the documentation. Oh, and keep an eye on the latest laws in your country too.
@Wren
Appreciate it!
Make sure prop screws are tight, keep the motors clean, inspect the vision sensors for damage, check the frame for any cracks… honestly, this list can get long. It is like a mini aircraft after all! The person who posted this has a bigger drone, so they probably have a lot more to check.
@Ellison
Thanks!
Basically, just keep it clean and avoid rough handling. Change props if you notice any chips or cracks. Unless you have a drone like the person who posted, you shouldn’t need to replace motors often.
@Clay
Thank you!
I wish I could afford a fancy drone. Been saving up to get one with thermal imaging and other features so I can take on more projects. Jealous!
It’s only around $13k, haha
The Autel Evo Lite 640T isn’t a bad option if you want something more affordable.
Do regular battery checks. They last about 120 cycles max, then you’ll start to notice issues. Set the battery station to discharge based on your schedule so it doesn’t die on you. Check the user guide for more battery tips to make them last longer. For storage, keep the charge around 50%.
Motors usually last about 200 hours, so consider replacing them around then, along with the props. Check for cracks on the body and screws on the landing gear, props, etc. Do vision calibration after firmware updates, and keep a good pre-flight checklist. Compass calibration is a good idea if you use multiple attachments.
I thought you were gonna say, “Don’t fly your drone indoors!”
Lol
Honestly, this advice is mostly for those with a setup like yours. I have a Mavic 3 Pro, which is great, but something like a Matrice with the Inspire camera setup is a whole different level. This kind of maintenance makes sense with your gear. I do agree with checking local laws and regulations, though.
@Quill
Haha, this is less about maintenance tips and more like, “Look what I’ve got!”
Davi said:
@Quill
posts pic of a Lamborghini
“Friendly reminder to rotate those tires, everyone!”
Corey said:
Davi said:
@Quill
Classic!
Davi said:
@Quill
:joy:
We just had a drone drop from the sky after a motor failure at 300 feet… scary stuff.
