Is there a way to screen share my Mavic 3 Pro feed?
I’ve got a Mavic 3 Pro and was wondering—can others around me watch the live feed from my controller on their own devices? Just thinking it’d be easier than everyone crowding around me to look at one screen.
If you’re using the RC Pro, you can connect a wireless HDMI transmitter. Just make sure it streams to an app that works on the viewer’s mobile device.
There might be some apps you can install directly on the RC Pro that allow livestreaming. I know of at least three, but you’d need to use your phone as a hotspot since LTE support outside China is limited.
With the goggles, you can plug in a phone running the DJI Fly app and it works fine. Not sure if that trick also works with the controller though.
I’ve used an Android app called ‘ApowerMirror’ to wirelessly send the Mavic 3 Pro feed to the RC Pro controller.
Do both devices need to be on the same Wi-Fi network or does it work peer-to-peer?
@Dru
Yeah, you’ll need to set up a hotspot on your phone and have the controller connect to it.
The app’s paid, but you can use it free for 10 minutes at a time—just reconnect every time it cuts off.
