I just got the drone today and the charging hub was working fine at first. Then this odd thing started happening and now I’m wondering if it’s normal or not?
It might think there’s no battery in that slot. Try unplugging the USB, taking the batteries out, and putting them back in to see if that fixes it.
When I unplugged the USB, the battery showed as fully charged. Then once I removed it, the next one started charging.
Man, I really hope it’s brand new. Would suck if the seller tricked you.
Oh no, I bought it secondhand… do you think something’s wrong with it?
Sometimes when batteries are left sitting for too long without a charge, they can go bad. Try putting the second battery into the first slot and see how it behaves.
@Miltan2
All the batteries seem fine actually. I just had to take one out for the next to start charging.
Jensen said:
@Miltan2
You could try putting the battery in the drone and charging it that way. Sometimes that kind of ‘wakes it up’.
@Miltan2
But they’re all working so far, so I don’t think anything needs reviving?
Jensen said:
@Miltan2
Oh sorry, I thought one of them wasn’t charging right.
Jensen said:
@Miltan2
Nah it charges fine. It just starts blinking when it’s full and then the next battery won’t charge until I remove the full one. So I’m guessing maybe I need to take each full one out manually?
@Jensen
That’s not how it’s supposed to work. Normally it should go through each one on its own without you doing anything.
Miltan2 said:
@Jensen
I got the whole kit for €240 and it flies great. Maybe I’ll try putting all the batteries back in and see if it sorts itself out.
@Jensen
This comment is empty, admin should fix
And yeah, it flies amazing, so I really don’t think I got scammed.
