Hey everyone,
I recently bought a DarwinFPV Baby Ape 2 HD and paired it with the Radiomaster TX16S, which I got because it should be compatible with future drones too. However, I’m running into some serious trouble trying to get them to bind together properly.
This is what’s happening:
- I’ve tried binding them several times, but something always seems to go wrong.
- I chose the TX16S because it’s supposed to have internal ELRS, which should work with my drone.
- I’ve been following YouTube tutorials, but I can’t find the “bind” option under the internal RF settings like everyone else shows.
- Instead, I’ve been using the ELRS Lua tab to bind, which technically works, but the drone’s behavior is off. The motors immediately go to max throttle and the drone doesn’t respond to inputs unless I use the killswitch.
Has anyone else used these two together and faced similar issues?
