Looking to buy my first FPV drone… any advice?
Hey everyone, I’m new to FPV and found a beginner quad kit plus the RadioMaster TX16S. Is this a good setup for someone just starting? Any suggestions on what to keep, replace, or add?
Not a bad choice at all.
Having a spare frame is smart!
One thing— with winter coming, the 85 might feel too big for indoor flying. If you’re mostly indoors, I’d suggest looking at the Meteor 75 or 65 instead. I fly a 65 myself; it’s great inside, though it doesn’t hold up well against outdoor wind.
@Owen
Thanks! I’ll mostly be outdoors, so that helps a lot. Appreciate the advice!
If you’re going to fly outdoors, consider EV800D goggles (watch out for fakes!) or, if you’re splurging, Cobra SD for better reception.
I switched to the EV800D from the Betafpv VR03, and the difference is noticeable—even up to 100m away in areas with trees and buildings. DVR recording is also a nice feature.
The quad should come with spare props and a battery, but I recommend at least 3 batteries. You might also want a small beeper in case it gets lost in the grass.
@Sage
Thanks for the info :slight_smile:
Go for the VR03s over the VR02s if you want to record your flights.
Grab extra batteries, props, and maybe a RadioMaster if you need a transmitter.
Thanks! How is the RadioMaster TX16S? Worth it?
It’s good, but if you’re on a budget, check out the Radiomaster Pocket—it’s half the price.
Used ones are also totally fine if you find a deal.
@Sage
Good point, thanks :slight_smile:
@Sage
I have access to a Mavic 3 controller—would that work?
Zen said:
@Sage
Nope, it’s not compatible because it’s DJI.
Don’t order straight from Betafpv’s site; shipping takes forever (like 6 weeks).
Definitely get the VR03s!
You’re set with this setup. Goggles are fine for now, and you can upgrade later. Don’t forget a good battery charger—don’t skimp on that. Cheap chargers are risky, and batteries can be dangerous.
