I just updated my Mavic 2 Pro to the latest firmware, which includes Remote ID. How can I verify through the app that it’s enabled?
Please note that the Remote ID serial number will only be visible in the United States. To find it, go to the DJI GO 4 App, navigate to the Image Transmission page, tap on the Settings icon in the upper right corner, then select “About” and look for the Remote ID serial number. I hope this helps. Thank you for your understanding.
There are two methods to verify if Remote ID is functioning correctly:
Method 1: Check the Remote ID status on the DJI GO 4 app. If there is an issue, it will show “Remote ID error.”
Method 2: Look for the Remote ID serial number in the “Available networks” of your WLAN. Start the drone’s motors using the DJI remote controller, then use your phone or tablet’s WLAN to scan for the Remote ID serial number broadcasted by the drone. If you see a string beginning with “RID-” followed by a 20-digit alphanumeric serial number, it indicates that the Remote ID is being broadcast correctly.
