Bought the Mini 4K a few days ago, and I’m really starting to feel like it was a mistake.
On bright days, the video is way overexposed, even in auto mode. When I switch to manual mode, I set the ISO at 100 and increase the shutter speed, which helps a little but ends up underexposing parts of the video that aren’t in direct sunlight.
Feeling like I should’ve just gone for the Mini 4 Pro instead. Anyone else had a similar experience with this model?
Edit:
I added a link to a video I shot in auto mode with no ND filters. Take a look:
Sunny Days Over the Hill: Drone View of a Quaint Small Town shot using DJI Mini 4K
Yeah, small sensors can struggle with dynamic range. A gradient ND filter might help a bit—higher density on the top and lighter on the bottom to balance things out.
I just added the video link. Curious if this filter would actually make a difference for shots like that?
Kai said:
Have you tried using a 64 or 256 ND filter yet?
Updated the post with a video link. Let me know what you think!
Actually, that quality looks decent! But trust me, adding an ND filter will make a big difference. You can pick one up for around $30, totally worth it.
I’ve got the Mini 2, and it worked fine (until I crashed it, haha). Since the Mini 4K is a newer version, it should perform better. Maybe share some screenshots of the issues you’re seeing? If you really think it’s a defect, you could try contacting DJI for a replacement.
What you’re dealing with sounds like a dynamic range issue. Small sensors can’t handle extreme ranges well. I use a Mini 3 Pro, and I feel it handles it okay for the size.
Just so you know, an ND filter won’t solve dynamic range limits. But shooting in DLog can help if your model supports it; it gives you a little more flexibility with highlights and shadows. If your Mini 4K can’t do DLog, then you’ll need to expose carefully to avoid clipping the brightest parts of your video. If you clip, there’s no way to bring that detail back.
Try exposing for the brightest area and raise shadows in editing—it should help!
