Thermal Camera Options for DJI Mini 3?
I’ve been using my DJI Mini 3 for some awesome aerial shots, but I’m curious about adding a thermal camera to the mix. Are there any thermal camera options compatible with the DJI Mini 3? If so, what’s the best way to set it up? Would love to hear your thoughts and any recommendations!
Thanks!
Adding a thermal camera to your DJI Mini 3 can enhance your aerial photography, but the Mini 3 doesn’t have native support for external cameras. One option is the FLIR Duo, a lightweight thermal camera that can be mounted on drones; however, you’ll need to find a suitable mounting solution for the Mini 3. Setting it up typically involves connecting the camera to a power source and ensuring it can communicate with your drone, which may require some configuration. Be mindful of the Mini 3’s weight limits, as adding equipment can affect flight performance. If you prefer an integrated solution, consider upgrading to a drone like the DJI Mavic 2 Enterprise Dual, which features a built-in thermal camera designed for such applications. Happy flying!
The DJI Mini 3 doesn’t support thermal cameras directly. For thermal imaging, you might consider using a separate drone equipped with a thermal camera, such as the DJI Mavic 2 Enterprise Dual or the DJI Matrice 300 RTK.
