I recently bought the Promark VR GPS quadcopter, but I’ve encountered a persistent issue during the final step of the Quick Setup process where I calibrate the GPS and attempt to fly the drone. The drone blinks continuously for about 5-7 minutes at this stage and then shuts off without resolving the problem. Although I’ve successfully synced the drone to my phone, I’ve been unsuccessful in actually flying it despite repeating the Quick Setup process 12 times. I did manage to fly it once on an early attempt, but the battery wasn’t fully charged, so I charged it before attempting again. Since then, I’ve been unable to progress. Any assistance would be greatly appreciated.
hi orienthal dones these are significant steps applicable which could guide u Calibration Process:
Follow the calibration process correctly to avoid flight stability issues. Check the user manual for specific instructions on calibrating the GPS and gyroscope. For example, the Promark P70-GPS drone has a step-by-step guide for calibration.
Faulty Components:
Inspect components like the IMU (Inertial Measurement Unit) or compass for any damage or malfunction, as faulty parts can prevent successful calibration.
Environment:
Calibrate your drone in an open area with a clear view of the sky. Avoid flying indoors or in places with poor GPS signals. If you’re in a remote area with limited infrastructure, try calibrating when you have better connectivity.
If your Promark GPS drone is having trouble calibrating the GPS or flying properly, there are several steps you can take to troubleshoot the issue:
- Check for Interference
- Verify GPS Signal
- Calibrate Compass
- Update Firmware
- Check Battery Leve
- Reset Settings
- Contact Support
- Consult Forums and Communities
