What does this blinking light mean on my Mini 4 Pro?
I have a DJI Mini 4 Pro, and the LED is blinking 3 times per second when I try to charge it. Anyone know what this means?
Sounds like an overheated battery. I had the same issue after a long flight. Just unplug it and let it sit for a few minutes before charging again.
Your battery is probably too hot. Are you trying to charge it right after flying? Let it cool down first.
Hey! For further help, could you confirm which model you’re using?
It’s a DJI Mini 4 Pro.
Thanks for confirming! The LED blinking 3 times per second means the charging temperature is too high. The optimal charging range for the Mini 4 Pro is between 5°C and 40°C (41°F to 104°F). Just wait for it to cool down before trying to charge again.
Try taking the battery out and holding it in front of a fan for a minute to cool it down.
I wish someone would invent a book that tells us how to use things we buy… like a manual or something :joy:
There’s actually a manual online that explains LED errors! Check it out here: DJI Support Manual.
@Dara
Lol, I think you missed the joke there.
Your battery is too hot. Let it cool down first.
It just means you’ve got an expensive drone :sunglasses:
Your battery’s overheating. Give it time to cool before charging again.
Just put the battery in a bowl of water and leave it in the freezer for a few hours. That always works for me!
Yeah, no. Don’t do that unless you want to turn your drone into an ice cube. Bad advice.
