What is this on the front of the controller?
And what does it do?
Antenna
Morgan said:
Antenna
Yup, on this controller though it’s so big it goes up to anelevena.
Jaden said:
Morgan said:
Antenna
[deleted]
@Hartley
Here for the free Blow jobs.
This is the old FPV Controller 2 which had a proper Transmitter in it. The FPV Controller 3 only connects to Google, which transfers the control signal to the Drone.
It connects to Google Cloud then retransmits it to the nearest datacenter; then from the antenna on the building to the drone.
@Jin
If you can’t be sensible, don’t post.
Brooklyn said:
@Jin
First day on the Internet?
It is primarily made for actual drones, and that is the antenna.
Would it benefit with the Avata 2 and if so, where do I get one?
Probably not, and you need the Goggles 2 as well.
@esleystanley
I’m running Goggles 3 with RC 3 and Avata 2.
@esleystanley
This would be a downgrade then.
@esleystanley
Got it. First time seeing it last night. Thought maybe I was missing something. Thanks.
@OrienthalDrones
Can you run the Controller 2 with the Goggles 3? If so, will it connect directly to the drone or does it still connect with the Goggles 3?
Luca said:
@OrienthalDrones
No.
Charlie said:
Luca said:
@OrienthalDrones
No.
Pls just don’t fly. If you can’t figure out the equipment, it’s best to stay home.
@esleystanley
Huh?
Most intelligent DJI pilot.
