Zuri said: @Washington
How does the Mini 4K compare to the Mini 2 SE? My friend has that one and says it’s ‘not too bad.’
It’s pretty much the same as the Mini 2 but with 4k video instead of 2.7k. It’s marketed as a beginner drone with features like return-to-home and quickshots but lacks obstacle avoidance, so you have to be careful. The Ascend, on the other hand, can barely manage any of that, especially with its lower-quality camera.
@Zuri
Obstacle avoidance can be helpful but only in specific situations. If you’re shooting in open spaces, a Mini 2, SE, or 4K should do fine.
If you want real obstacle avoidance, you’d need something like the Mini 3 Pro, which is around $500.
I used a DJI Spark with front obstacle avoidance but sometimes turned it off to get certain shots. A lack of obstacle detection does make you more aware of your surroundings.
The Mini 4 Pro is also in the same weight category and has side avoidance, but that pushes the price over $700.
edit: for your window scenario, a Mini 2, SE, or 4k could make it, but it’s risky. A higher-end drone would prevent a crash unless you disable obstacle avoidance before trying.
