So I was trying to use Active Track on my DJI Air 3, but it failed miserably and led to a crash. The drone was following me while I was riding my bike, but it just couldn’t keep up with the terrain changes and altitude shifts. Anyone know why this happened?
I’m not an expert, but it looks like the drone is locked at a certain height while the road keeps rising as you ride.
Wouldn’t the downward sensors stop it from crashing?
@Aspen
Same thing happened to me recently while I was filming a motorcycle. My drone lost elevation and crashed. Was yours in sport mode? It doesn’t prevent impact but softens it a bit if it’s in normal mode.
@Aspen
No, when it’s going over 20m/s, the obstacle sensors switch off.
Scout said:
@Aspen
Really? Didn’t know that.
Scout said:
@Aspen
Yeah, in ‘trace’ mode it’s off at 10m/s and completely off in ‘parallel’ mode. Terrain and lighting also impact the sensors.
Scout said:
@Aspen
The speed in the video looks under 40 mph.
Scout said:
@Aspen
Keyword: ‘looks like.’ It’s hard to judge accurately.
@Aspen
The altitude change on the ground is just too sudden for the drone to adjust.
@Aspen
Might be because it’s in sport mode. That disables sensors and increases speed.
Kip said:
@Aspen
I was actually in normal mode.
Kip said:
@Aspen
Sensors might just be too slow to react at high speeds. What puzzles me is why it dipped right before hitting.
Kip said:
@Aspen
There’s a video by a guy called DC Rainmaker on this. It explains how steep terrain can confuse the sensors. Not sure if DJI has fully fixed this yet.
@Keagan
Actually, his name is TC Rainmaker.
Kiran said:
@Keagan
Oh, thanks for the correction!
Kip said:
@Aspen
The drone’s angle impacts its altitude adjustments.
@Monroe
I have a Mini 3 Pro, and it can handle steep changes even in sport mode. It might depend on how fast you’re going, or maybe the Air 3 is just different.
Kip said:
@Aspen
I have used my Air 2s in similar situations on my e-bike. It keeps the height steady even with steep terrain changes. Maybe try setting the height higher next time?
Agreed, looks like it couldn’t keep up with the height change.
